Coating as durable as stainless?
Old Mar 29, 2004 | 12:10 PM
Parrydise7's Avatar
I always wanted stainless steel headers, and then SLP disco'd its tri-y. Is it true that with a coating, non-stainless headers are almost as durable as ss?
Old Mar 29, 2004 | 05:45 PM
25THRSS's Avatar
probably even more durable
Old Mar 30, 2004 | 01:02 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
slp's headers will still develop surface rust, don't believe the hype, it's a lower grade 409 stainless.
Old Mar 30, 2004 | 01:10 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
ya, my boss has SLP LT's on his 99 TA and they have surface rust, and he only drives it AT the track, not even to it. trailers it there.
Old Mar 30, 2004 | 10:54 PM
davehamilton's Avatar
Hello, All stated above is true, It is a very low grade stainless, we always get askes "why coat my y-pipe,? It is SS.) The answer is #1 it is most likely to get wet being @ the underside of the car and the welds are not SS thus prone to accelerated rusting and #2 the thermal reducing properties of the ceramic coating help keep the fluids cooler in the oil and trans pan. You can research the rust warranty on the SS VS. the ceramic coating and that will tell you alot. The coating also improves the flow as colder gasses mover quicker and more efficiently, As well as the beauty of highly polished aluminum that does not blue or discolor. All you have to do is polish them every now and then with alum. polish like your alum. wheels!!!
ACS
Old Mar 30, 2004 | 11:08 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Go Dave, u tell them! I dont miss stainless steel one bit with ACS coating on aluminum instead.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Night rider327
Sep 25, 2015 04:47 AM
