Did you put the braces back on?
Old Mar 29, 2004 | 06:24 PM
25THRSS's Avatar
I want to get rid of the braces for the serpentine setup that attach to the exhaust manifolds. I just think it's one less thing to clutter the engine compartment up with. I can't see deleting them causing any problems, but has anyone had any problems doing this?
Old Mar 29, 2004 | 06:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Did you put the braces back on?
Well I removed mine when I installed my headers and I probably should have left one on. I say this because at the time I didn't have the top brace that bolts into the edelbrock manifold either, because I was to lazy to dril and tap it at the time. Anywhoo, when I last drove the car I heard this horredous rattle in the front of the car. I later found out that the top accesoy bracket bolt sheared off into the head. An easy out fixed the problem and I replaced it with a better bolt. I also drilled and tapped the intake brace as well. I shouldn't have any problems now. So what I am getting at is this. If you only remove the exhaust brackets and not the intake as well you should not have any problems.
camaro11j
Sep 19, 2018 08:49 AM
justin57
Aug 20, 2015 07:05 PM
cstrobel65
Aug 15, 2015 10:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
NBrehm
Aug 5, 2015 07:57 PM
