CAT Heat shield under car, Can I remove?
Old Apr 13, 2004 | 03:58 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im talking about the heat shield that is bolted to the underside of the car where the cat used to be. I guess it was there to keep heat from under the passenger seat...
I no longer have a CAT just a straight pipe so would it be ok to remove that and leave it off? Reason Im asking is because Im going to get my MAC SFC's welded and that piece gets in the way.
Old Apr 13, 2004 | 04:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can remove it if you do not have a cat. Cats get very hot and that shield is needed there when you run one.
Old Apr 13, 2004 | 04:43 PM
Excellent, thats what I wanted to Hear. I already removed it since it has to come out anyways for the SFC's to go in...I just didnt know if I had to put it back on.
Old Apr 13, 2004 | 04:52 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Cool, now you can lose one more thing that will vibrate and make noise.
Old Apr 17, 2004 | 07:51 PM
Eric_7810's Avatar
Car: 1986 Z28
Engine: LG4 305ci
I had the same thing...it was rattling with my speakers so I removed it. I do not have a cat. Nothing happening under there, so yea...no cat=no problems
Old Apr 17, 2004 | 10:07 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Amen. It seems I tend to fix one rattle, and find three more
Brandon
onefreakz
May 14, 2018 12:15 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
