Dumb question on exhaust tip
Old Apr 14, 2004 | 12:28 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
i was wondering if i have a true 3 inch exhaust coming out the back does that mean a 3 inch exhaust tip would fit? or the tip would have to be bigger then 3 inch?
thanks
Old Apr 14, 2004 | 02:17 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
The 3" pipe going back is more than likely a 3" outside diameter pipe, so to fit on there you would either need to flare a 3" OD pipe, or get a tip that has a 3" inside diamter slip on the end...
Old Apr 14, 2004 | 02:48 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
thanks the reason i ask is because im getting rid of a pair of tips that are 3in x 9 and some guys asked if they will fit on his true 3 inch pipes
Old Apr 14, 2004 | 11:20 PM
25THRSS's Avatar
you could just butt them up and weld
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
BurlyChev
Aug 22, 2015 11:42 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
