car eating cats
Old May 6, 2004 | 04:22 PM
91Z28-350's Avatar
car eating cats
Grr, second pair of cats and after about 2 weeks, it's starting to rattle again. What the hell is wrong? I don't seem to be burning oil, and I don't seem to be burning coolant. It doesn't seem like I have a dead cylinder (all spark plugs show sign of being used). I have new spark plug wires. I can try a new cap, rotor, and a heated O2, but anything else?
Here are my mods. TB bypass, K&N, removed air baffles, shorty headers, carsound cats, flowmaster Force II catback.
I dyno'd it recently, 245HP at the wheels on a Dynojet, AFR hits at the lowest point 11.3 or so.
Old May 9, 2004 | 05:27 PM
Marc 85Z28's Avatar
Do these cats require air injection? And if so, is yours working properly - or even existant?
Old May 10, 2004 | 12:27 PM
91Z28-350's Avatar
Hi,
Yes, it requires AIR. I presume it works, how would I check? The pump is not seized as far as I can tell. The check valves are in order. I guess that leaves the solenoid.
Old May 10, 2004 | 12:32 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by 91Z28-350
Hi,
if its the pump, i'll give you mine.... athough its probly cheaper shipping wise to get one from someone closer to you..
smog equipment is cheap since half the country takes it off...
Old May 10, 2004 | 02:07 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
On my 91 Z28 305, I burned 2 cats because of a bad O2 sensor. The last one was a Random Technologies - ouch! Also make sure that your fuel injectors are not leaking, too much fuel in the exhaust will burn the cats also, at least that's what Random Technologies told me to check when I called them about their cat burning up. Good luck.
Old May 11, 2004 | 05:09 PM
91Z28-350's Avatar
O2 is a new Bosch, but I just ordered a GM heated. The injectors are fairly new, but that doesn't mean it isn't leaking. I'll change the O2 and check the AIR solenoid as suggested, first.
Thanks for the replies.
Old May 11, 2004 | 09:24 PM
laiky's Avatar
I lost my cat due to a high rpm backfire. Loud bang, big ball of precious metal dust!!! It cracked and then over about a week rattled itself to dust.
onefreakz
May 14, 2018 12:15 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
Amillionoh7
Aug 7, 2015 01:24 PM
