Whats the best Way To Plug AIR Holes In Exhaust Manifolds???
Old May 10, 2004 | 12:42 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i just took off my AIR tubes after relocationg my heater contolr valve and removing the entire AIR system but need to know the BEST way to plug up the original AIR holes in the exhaust manifolds. i got the 1/4" pipe plugs should i just screw them in?? ive heard they come loose very easily. i have some QUICKSTEEL, would that help me???
Old May 10, 2004 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The best thing to plug the A.I.R. holes is A.I.R. tubes.
So, you're really asking what's the 2nd best thing...
Old May 10, 2004 | 09:03 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
lol i guess youre five7 but i dont have those anymore (well i have them in about 20 pieces) but the SECOND best thing would be what?????? o and for some reason the plugs i bought arent threading all the way into the manifolds. they stop right after they entree pretty much but have the same thread as the ones i took out. what gives?
Old May 11, 2004 | 12:23 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I used brass plugs. Short (like 1/4" long) bolts with the right thread would work too.
Old May 11, 2004 | 12:59 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well the plugs did fit.........i just coudlnt hand tighten them but i took the old ones off by hand after they were loosned...o well. i didnt use any jb weld or quick steel so if one falls out ill go get another and put in it, im out 50 cents
Old May 19, 2004 | 12:43 PM
Drew's Avatar
The reason they didn't thread in is the ports in the manifolds aren't a straight pipe thread. They're flare seat tube threads. Go to a good autoparts store, the right plugs are fairly inexpensive and will actually seal without damaging the manifolds.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
transaero
Aug 31, 2015 01:14 AM
timonator
Aug 11, 2015 09:56 PM
