Is my O2 in the right place
Old May 11, 2004 | 12:20 AM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I had a guy weld my O2 bung for my car. He put it on the Y-pip near the first bend, not on any of my headers. They are Headman Shortys, with Y-pipe. I was just wondering if that is too far back to get a proper reading. He said that was the only place he could put it.
Old May 11, 2004 | 12:21 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its near the header, its probably fine.
Old May 11, 2004 | 05:34 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
the correct place for the O2 is in the driver side header collector, seeing as it is further along the pipes, it will take a little bit more time to heat up and get a reading, not much longer, it will eventually get there, you should be fine where its at.
Old May 11, 2004 | 10:14 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
As far down as this has been placed, I'd go with a 3 wire heated sensor. Lot of posts on how to do it (and why). Not an expensive mod, and sure can't hurt, can only help.
Linson
Oct 24, 2025 02:00 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
