When is 3 inches too small?
Old May 14, 2004 | 11:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
how much power can you push through 3 inch exhaust tubing?
I got a flowmaster catback and like it alot but was thinking a true dual setup like Willie's or others on true dual picture collection. I wish I would have researched more on true duals before buying the catback. I was in a hurry to get a nice sound but now would like to get a dual made in near future. I need other things done first but is it really worth the hassle?
Old May 15, 2004 | 05:47 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
You can get about 450-500hp out of a good 3in system. After that then you are starting to push it a little. Plus, if you go duals you will loose a lot of gound clearance that I know many people don't want to give up. The single 3in gives good ground clearance and performance.
Old May 18, 2004 | 01:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Correct. Once you start making over 420 to 450 at the wheels upgrading to a larger pipe size would be benificial. There are just too many negative things with duals on a 3rd gen. For those reasons I will always run a single.
Old May 18, 2004 | 03:40 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'd also say about 450HP is when you start really choking... Maybe 425HP.
If you are (or know) a good exhaust fabricator you can run duals and have just as much ground clearance as single. Its just you see most cars with duals are mainly "street/strip" kinda cars so ground clearance isnt there #1 concern. BUT if you want duals and stock-like ground clearance its very possible.
Old May 18, 2004 | 07:24 PM
2out_The_Left's Avatar
i seriously wouldn't waste the cash on running the tru-dual on a mild 350 TPI. wait till you have some serious mods or a charger. it is nice to have, but you can spend the money on other things that you'll benifit more from.
Old May 19, 2004 | 12:22 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
I see lots of true dual setups that look like they are fine. if they use a modified crossmember and run the pipes through there, and take out the support bar using SFC's instead then whats the problem?
Jorlain
Oct 8, 2015 01:57 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
ericjon262
Sep 11, 2015 06:07 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
