O2 Sensor Stuck
Car: 87 IROC Z
Engine: 5.0 TPI
O2 Sensor Stuck
Ive been trying to get the 91rs to pass the Emissions test and Ive replaced everything except cat and o2 so cheapest first.
And i knew it was going to be froze in there cause of the exhaust heat. And after pretty much destroying it (only the hex, Nut) remains in the Ypipe. I think It needs to heated before removal.
Now I have to drive 5-7miles to my shop to lift it and get torch on it. CAN i drive it for short distance will it run ok.
thanks
Brian
thanks
Brian
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can run without the 02 sensor but your car will act funny once it goes into closed loop. If you are lucky, pick a cool time of the day when you haven't run your car. Fire it up and head to the shop. You may make it there in open loop when the car doesn't rly on the 02. Did you try PB blaster? That stuff works great on helping break up rust seals.
Car: 87 IROC Z
Engine: 5.0 TPI
I tried wd40 but the nut is starting to round off. I was going to bring home 6pt 22mm but i forgot. so i might just drive it in work in the morning then i dont have to lay on the blacktop.
Thanks alot shifty
brian
Thanks alot shifty
brian
You're going to drive to the shop to get it heated up with a torch? Your exhaust will be plenty hot to pull it off after running the car for a minute. Make sure you use anti seize on the new sensor.
Car: '90 RS
Engine: 377 LSX
Thanks alot shifty
brian
Thanks alot shifty
brian
1nastygta
Sep 24, 2015 08:58 AM
