quick help w/header install........got to be in the exhaust shop tomrrow!!!!
Old May 26, 2004 | 01:22 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ok its 1:45 am where i am and i need to get my headers and y pipe on before it goes in the shop tomorrow........how do i get this little sensor off without breaking it. it needs to come off to get the headers in. also, do i use anything like sealant to hold on my new header gaskets????
i desperatly need some quick help guys!!!
thanks
Old May 26, 2004 | 06:11 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
squeez on both sides of the connector and it will come off. then just take the right size wrench and take the sensor out. You don't need any sealant for the header gaskets. Also the headers should go on without taking that sensor out. I didn't have to remove mine at all.
Old May 26, 2004 | 05:07 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
What sensor is that?
It can't be the O2 cuz its not in the header.
Old May 26, 2004 | 05:43 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
it's the coolant temp sensor for either the guage or the fan. can't remember which.
Old May 26, 2004 | 08:54 PM
Are you sure because there is an open hole in my engine block right there and the wire is sitting unconected in my engine bay. My car does overheat so that would make sense. However, autozone.com says that it is UNDER HOOD, CENTER, UPPER ENGINE AREA, FRONT OF CARBURETOR, PASSENGER SIDE OF WATER OUTLET, MOUNTED IN INTAKE MANIFOLD
Old May 26, 2004 | 10:51 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
That is the radiator fan switch... It will probably crumble in to many tiny pieces if you try to remove it.. Not surprising though. Just will need a new connector..
Old May 26, 2004 | 10:55 PM
Thanks!!
formula_novice
Sep 5, 2015 03:58 AM
TheExaminer
Aug 26, 2015 04:59 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
happyhapka
Aug 15, 2015 04:42 PM
