Flames Shooting Out Headers
Old May 13, 2004 | 11:52 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I just got my motor back in and trying to start it for the first time since March, and was hoping to hear it run w/ open headers but instead, I've got fire coming out the exhaust. Is this normal or do I need to check the timing again? It won't start but I could certainly roast a few marchmellows under there.
Old May 14, 2004 | 12:08 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
How short are your headers? What engine?
Old May 14, 2004 | 12:13 AM
jgifford's Avatar
Car: 1986 Z28
They're just the hooker 2055, not the LT's. It's a 355ci with a long, long list of mods.
Old May 14, 2004 | 12:27 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
I would imagine that it is okay. Should be normal. But i'm no expert...
Old May 14, 2004 | 01:32 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
seems normal to me
i'd put some exhaust on there though, don't you have a y-pipe you could bolt up?
Old May 14, 2004 | 01:36 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i assume its expected, with no cat to burn up the extra fuel/fumes
Old May 14, 2004 | 11:27 AM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
its normal, caught the 69 on a fire a few years ago cus of that(open headers, no dumps or anything), Didnt realize how far the flame was shooting back until it got dark, then it was to late, up in flames she went. Id highly recommend an exhaust on it
Old May 14, 2004 | 12:23 PM
davehamilton's Avatar
Hey, Be carefull or your gonna fry the coating!!!
Old May 14, 2004 | 04:22 PM
thecoolone's Avatar
Car: 89 GTA
It's just unburned fuel catching fire from the heat of the headers, no biggie, but probably not safe.
Old May 14, 2004 | 04:40 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
PICS! VIDEO!!!
lol, jk... try not to roast anything important under there...
but if you do happen to get pics, post em up!
Old May 14, 2004 | 06:12 PM
Car: 82 El Camino
Engine: built 355
no pictures or video, but one hell of a lesson learned and definetly not forgot.
Car: 82 El Camino
Engine: built 355
sorry double post
Old May 19, 2004 | 10:38 AM
jgifford's Avatar
Car: 1986 Z28
Well, turns out the dist. was a 180* out so turned that around, bolted the ypipe up and turned it over once and boom, she fired right up. Now I'm thinking I may have an exhaust leak, (other than the fact there's nothing after the ypipe). As far a tightenting the ypipe, does the ball flange keep it sealed or do I need some kind of gasket for it? Also, I snugged it up pretty good, but it's not super tight like I did on the manifold, should I go back and put the squeeze on it?
Old May 19, 2004 | 05:36 PM
No gasket, Sqwwweeezzzz it gentleee!!!
Old May 26, 2004 | 10:09 PM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
i would guess timing thats what mine was
Old May 26, 2004 | 11:45 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
id run a full exhasut just y pipe and your gonna crack your heads
Old May 26, 2004 | 11:46 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
your engine bay is pretty.
180*?!??! i can imagine that would cause some small problems!
-chuck
Old May 27, 2004 | 12:48 AM
CamaroPimp's Avatar
Car: 95' Z28 T-top; 4:10 Posi with KYB adjustable gas shocks; Hooker Super Comp Shorties; K&N; Flowmaster
Engine: LT-1 350
Sexy engine!!:hail: :hail:
Hmmm. Oh yes and about those flames... Ive been thinkin of setting a controled burn in my lawn so I can work with the grass..Ya think You could drive by at about 10 MPH and get the grass going ...Get sopmething on there!! Y-Pipe wounds good..with the rest of the exhaust..Go Flowmster..Flowmaster with hookers sounds beasty!!:lala:
Matt
Old May 27, 2004 | 01:17 AM
jgifford's Avatar
Car: 1986 Z28
I never was a big fan of Flowmasters. I put a Random Technology hi flow cat followed by the SLP catback system. I also had a cut out installed in front of the cat and McCord Power plate sitting in the garage. I'm really looking forward to hearing the SLP's once it breaks in, she already has a beasty sound.
Thanks for all the compliments on the motor, I have a few pics up and list of most of the mods done to it HERE. Check it out and let me know what you think.
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
