hooker or edelbrock
Old Jun 2, 2004 | 10:52 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
hooker or edelbrock
i was just wondering what is a better cat back for the third gens i am ordering it for my 1992 i am sort of leaning toward the hooker system because it is cheaper by almost a hundred dollars and it comes with chrome tips but which one sounds better and is a nicer system
Old Jun 2, 2004 | 11:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will be happier with either. I have never heard the edelbrock system but the Hooker is hard to beat.
Old Jun 2, 2004 | 11:46 PM
Engine: LO3 and LT1
i was also wondering will the 83-85 exhaust fit a 1992 with a slip on cat . isnt the only difference the four bolt flange and if i cut that off it will be the same as my 3 inch cat right?
Old Jun 2, 2004 | 11:51 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The exahust routing throughout the years never changed. However the cat and pipe size did between models. Chances are the 83 thru 85 kit will only fit with a little fab work. Why not get the one specific for your year?
Old Jun 2, 2004 | 11:53 PM
Engine: LO3 and LT1
it is 60 dollars cheaper was just wondering what the big difference would be it says it is 3 inch i pipe with 2.5 inch tails
Old Jun 2, 2004 | 11:54 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The only difference is how it mates to the cat. Other than that the kit is the same. It may be cheaper in the long run to get your model year specific if you cannot do the fab work yourself.
Old Jun 2, 2004 | 11:56 PM
Engine: LO3 and LT1
doing the work should be no problem really all i should have to do is cut the four bolt flange off the mates to the 83-85 car right?
Old Jun 3, 2004 | 12:19 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
For the most part. Your 92 cat should accept a 4 bolt flange as well but there may be a slight alignment or hanger difference between the two. I am not familiar with the earlier set-ups to be certian. Either way you should be fine and come out 60 bucks cheaper.
Old Jun 3, 2004 | 07:15 AM
Engine: LO3 and LT1
no what i was saying is that i have just a catco slip on 3 inch highflow cat that i ordered with my edelbrock headers and y pipe. i would have to cut the flange off to mate the exhaust with the cat. the pipe will just slip inside the cat and sometimes the exhaust pipe is an oval shape going into the flange so i might have to round it back out with a mallet or something. then i will just make another custon hanger.
Old Jun 11, 2004 | 12:41 PM
Engine: LO3 and LT1
i got my exhaust and cut off the flange and rounded out the pipe today now i just have to wait for my boss to have an opening in his shop so i can use his pit to installl it
Pac J
May 17, 2020 10:44 AM
no green
Jan 9, 2016 09:22 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
