Header install A/C Bracket Mounting
Old Jun 11, 2004 | 02:31 PM
yzarcem's Avatar
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
I just wanted to post this information in case anyone ever does a header upgrade, throws away the old bolts, then realizes they need the bolt for the A/C & Power Steering Bracket (like I DID). My Camaro has the AC & PS on the Driver's side.
Of Course, you have to cut the bracket because it won't wrap around the header port to the second bolt.
You'll need a bolt that is ~ 3 3/8" Long. Consider one end as the header bolt...1 1/4" including the head. Then you need a spacer that is 1 1/8" long. Then you bolt your bracket against the spacer & you are in business. See attached diagram:
Attached Thumbnails Header install A/C Bracket Mounting-spacer.jpg
Old Jun 12, 2004 | 12:41 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moving to Exhaust.
Old Jun 30, 2004 | 01:13 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
great info. where can one get spacers?
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Wesly_66
Aug 26, 2015 09:55 PM
sreZ28
Aug 14, 2015 07:48 PM
