Hey guys i know im a pain but I finally have my headers installed hedman shortys without air pipes. There was a hose i disconnected its all shot up anywyas was from cat to some hose in engine bay area whats this called? Is it important? How do i go about replacing it i showed the guys at autozone and he was like i have no idea what thats for he said that wasnt anything that came with car. Its 85 camaro berlinetta 305 thanks in advance
Quote:
That is your AIR tube from your smog pump/exhaust manifolds. It is really best if you use a cat that does not need an AIR tube when you go with non AIR hedders. You can clog your cat up over time if you are not within 1% of stochiometric combustion. Most 3rd gen cars are not once they are modded with the stock tune. I run a cat with a capped AIR tube but I know I am on limited time before it clogs. This tube is useless once you go with non AIR hedders.Originally posted by goinginsane
