slide fit cat
slide fit cat
i have a 2.8. I was just curious how the cat is held on at the front side (i know there is a clamp at the back side). It appears to be a slide fit connection where the cat slides over the Y-pipe. My cat (i think) is making a bit of noise and I would like to remove it and take a peek. Just it just slide off or is there some sort of cement or something used to hold it on???
Transmission: 4L80E/4L80E
There's no "cement". It's either welded or clamped on. Either way, something typically has to be destroyed in order to remove it (notice I said "typically" - you may be able to get it off w/o destroying something).
ambainb
Apr 25, 2016 09:21 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
