header Q's
Old Jun 25, 2004 | 09:25 AM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
header Q's
dont know what i should do.....looking to buy hooker shorty headers for my ride. the problem im having is my car has 2 cats with air, hookers will come with y pipe for 1 cat. i already have 3 inch flowmaster american thunder cat back installed.
im going to have a cat installed, should i go with 1 cat or 2.....ether way how am i going to do this? and what about my A.I.R system? remove it?
Old Jun 25, 2004 | 10:06 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you do not have visual inspection where you are I would replace your dual cat set-up with a 3" single cat. You will still be smog legal and you can still hook up your AIR if you get the right cat. You could also remove your AIR if you wanted to and run a cat without AIR. Your hedder selection has now broadened.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
