Hooker cat back and stock converter.
Car: 1999 Trans Am WS6
Transmission: A4
I have been planning on getting the Hooker Catback for a while now and was reading in the Jegs catalog that it will bolt up to the stock converter. The current pipe is 2 1/2 inches and I have read that the Hooker is a true 3 inch I-pipe. My cat appears to be stock. I was going to get Hooker headers and a new cat so it would all be 3 inch but if it will bolt up to the stock cat I'll save my self some money and just get the catback.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
exhaust will only flow as fast as the smallest point will allow it too. if i were you i would go ahead with the all 3" deal. if your just looking for better sound, then go with your idea, but for best performance results, going with 3" all the way will work best.
i don't run a converter, never have, but i have heard that the stock one sucks really bad.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The Hooker cat-back in question will have a reducer attached to it to mate to your stock cat. That is why you buy the one tailored to your year/engine car.
Axle/Gears: 9-bolt/3.45
Geez! I wish this site would quit moving around, lol!
ZROC86, you can do just what you want to do. The TPI engine's stock cat has both a 3" inlet and a 3" outlet. So regardless of what size your current I-pipe is(which should actually be 2 3/4", not 2 1/2"), a 3" cat-back system will mate perfectly, providing it uses the same kind of connection, which you say it does.
dhonda200
Aug 11, 2015 11:50 PM
