Venturis
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Venturis
My current exhaust is Hooker Long tubes, mandrel bends to two 2.5" catcos, mandrel bends to a x pipe, then 2 3" dynomax bullets. I really really like the way it sounds. It drones alot while at cruising speed. I know i read a discussion on these before, but couldnt seem to find it tonight. Im abandoning this setup (due to ground clearance) in favor of something like *******, but wanted to run the catcos and the bullets, but want it a little bit quieter. Does anybody know if any other companys besides Dynatech makes these and for anything less then the $60 they want?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I wouldn't use any of those "sound absorbing/dissapating" cones or inserts if I were you. The bullit mufflers are causing the drone. I would wait until you hear your new system with the cat/s. They significantly tone down your exhaust and mellow out the sound and act just like one of those cones. Except these help the environment as well.
drex
Carburetors
Mar 20, 2006 04:03 PM
