headers on a 85 305 z28 with emissions
Car: 91 Camaro Z28
i bought the edelbrock 350-6871 on jegs.com and i was wondering if i will have any problems with the brake lines or the ac box also the ac condenser since i want to keep the working ac in the car. it looks like i got room but just wondering if anyone ran into any problems?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You should be fine with everything. You may need to move stuff out of the way by unbolting it but everyone installs these things slightly different. You can bend the brakes lines out of the way gently if they come in contact with the primaries.
Transmission: 4L80E/4L80E
Modification of one of the AC brackets is often required. The instructions should tell you what needs doing.
