open shortys vs. open L/Ts
Old Aug 10, 2004 | 01:55 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I have edelbrock tes headers and I was going to go with some hedman longtubes but I was thinking and i would like to lower my car and also I can;t justify it, If i get two 2 1/2inch pipes coming off the headers with cutouts right there then aftere the cutouts have them merge into the I-pipe. Woudl longtubes with cutous really make more power thewn the ope shortys or is the gain barly noticable?? thanks
Old Aug 10, 2004 | 08:42 PM
Car: 89 Formula
Engine: Carbed 5.7
come on someone must have somthing to say
Old Aug 11, 2004 | 03:23 PM
Shagwell's Avatar
Car: projects.......
I have headman lt's and my car is dropped 1.5-2 ish. Problem is that the headman's have the collector really tight to the floor(points directly at clutch slave cylinder) and I've heard people say that you can't use them on a manual trans car because of this. I'm running a mechanical clutch w/ the trans standing up square, so I get away w/ this. - They should make a difference.
Old Aug 12, 2004 | 10:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The simpliest thing would probably be a "Y" in each down-pipe that goes to a cut-out. You would want the length of the tube going to the cut-out to be similar to the length of long tubes with a collector extention - something along the lines of 35-40" from exhaust port to cut-out opening.
Rousseau92maro
Feb 1, 2016 05:12 PM
Johnny*G
Oct 20, 2015 12:37 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
3.8TransAM
Sep 17, 2015 02:16 PM
Night rider327
Sep 16, 2015 02:20 AM
