Loss of low end with open headers normal?
OK, I finally got my modded L98 running. It's now got a ZZ4 cam, and SLP headers. It's currently running wide open headers. I also have the stock 2.73's and stock 700r4. (for now
It runs great, and it's noticeably quicker, but it seems to be a tad sluggish at low RPM's. I know that gears and torque converter will help, but will the exhaust system help with this in the meantime? I know technically it will help a little with the low end torque, but will it be noticeable?
....I hope to have my Carsound cat and Loudmouth installed in the next few days, so I guess we'll see!
)It runs great, and it's noticeably quicker, but it seems to be a tad sluggish at low RPM's. I know that gears and torque converter will help, but will the exhaust system help with this in the meantime? I know technically it will help a little with the low end torque, but will it be noticeable?
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
My car is always a little snappier in the low RPM's going through my exhaust, but when I open the cutout... it screams alot more in the high RPM's and makes more overall hp & torque.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Are they long-tube or short? What size?
Generally shorty headers make less low-end power. So do large tube headers.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Shifty is right on the money. If your headers are designed to be run open, they will have extensions or megaphones on them to provide scavenging waves. They will still give you a torque peak higher in the rpm band than a full system.
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
torque tubes?
yes, 18" of pipe sounds about right
from what my bud told me they help the exhaust flow better and allow the O2 sensor a better reading
another one,
another one,
theshackle
Sep 17, 2020 08:26 AM
