help me out here.
Old Aug 17, 2004 | 03:52 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
help me out here.
had the exhaust done with a new muffler and tail pipe and tips back in march/april. one of the hangers on the exhaust broke a few weeks ago. im finally getting back to the exhaust shop. when they originally did it i figured they would have made the tips evenly spaced but they didnt and didnt tell me until AFTER they had it all welded up. they said that there was no way to make it even. here is what it looks like. when i go back to have them fix their POS hanger should i tell them to fix the tips too. were they blowing me full of smoke when they said that it would work to make them even?
Old Aug 17, 2004 | 03:58 PM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
Don't know what their reasoning would be...
I however, can't see any reason why they could not make them even. A little bit of work may be involved, but thats what they get paid for.
The only problem I can see now is that they may try and charge you to 'refit' the tips. I guess it will depend on how well you know these guys or what kind of a shop they are really running.
I wouldn't put up with any **** about them not being able to line them up. To me, that is straight bull.
Old Aug 17, 2004 | 04:20 PM
92MaroRS's Avatar
i think their reasoning was that the spare tire well was in the way or something along those lines.
Old Aug 17, 2004 | 08:42 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes, they are blowing smoke up your ___ to say it can be corrected. That's just being plain lazy.
This is a fairly common problem when getting an exhaust fit/fabbed at a shop. The underside of the rear of these cars is not symmetric and most shops put the exits to hug the outermost parts of the underside on these cars. Obvoiusly, the one side housing the spare has more width.
The (easy) solution, chop 1.5"-2" off the drivers exit off the muffler outlet pipe to make it hug the trunk well. This will balance out the problem.
I would personally be pissed to pay $$ for some slapnut to jackleg my exhaust and then be charged extra to have the (same) shop re-fix it the way it should have left the in the first place.
*edit.. re-looking at the pic.. your pass side pipe doesn't seem to be all the way out to the pass side either contributing to the imbalance (assuming the tips have a center inlet)
Old Aug 17, 2004 | 09:43 PM
92MaroRS's Avatar
no the tips are no center inlet. the inlet on the passenger side tip is on the passenger side of the tip and the inlet on the driverside tip is on the driverside of the tip.
Old Aug 18, 2004 | 08:23 PM
deadbird's Avatar
Engine: TPI 305/ v6
I mean't "can't" in the above post btw (....to say it can't be done...).
Guess I should learn to proofread a little better
Old Aug 18, 2004 | 09:01 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
dude they are jerking u around to say that it isnt fixable! I say dont stand for it..........you dont bend your **** in half for noone!
I would stand there and watch when they fix it........tell them bs like a bunch of your buddies are about to do exhaust, and u were going to reccoment their shop, but not anymore...........that works sometimes.......trust me.
Old Aug 18, 2004 | 09:33 PM
92MaroRS's Avatar
well its suppose to go to the shop for a broken hanger ont he tail pipe and to 'see' if they can fix the tips. first of all im going to ask if i have to pay for this and if they say yes then im gonna say take my car off the lift. ill do it myself. i do have access to a welder and other misc. stuff.
Fanatic1074
Oct 3, 2022 05:57 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
LC2 TECH
Oct 13, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wstephan96
Sep 25, 2015 04:28 PM
