Reducer help?
Old Aug 29, 2004 | 09:40 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Reducer help?
ok i decided im gettin a 3" cat-back exhaust but i only have the stock 2 1/2" or 2 1/4" cat. so i wanted to just weld on a reducer, the problem is how can i do this with chevys funky device taht connects the cat and the intermidet pipe( the think usin 2 bolts that are slid on to the pipes? how would i make it be 3"
Old Aug 30, 2004 | 11:18 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Reducer help?
Most cat backs tailored for your engine code are 3" and have the reducer already attached and will bolt right up to your stock cat. You can just cut the reducer off when you go with a 3" cat.
Old Aug 30, 2004 | 10:40 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
i wanna get the flomaster american thunder system. part #17233.
but i wanna make sure it has the correct reducer already attached..
http://www.flowmastermufflers.com/cg...ter/17233.html
Old Aug 30, 2004 | 11:51 PM
25THRSS's Avatar
you want part # 17234
http://www.flowmastermufflers.com/cg...ter/17234.html
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Pac J
May 17, 2020 10:44 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
gord327
Oct 3, 2015 01:25 PM
dimented24x7
Sep 17, 2015 06:58 AM
