is there a trick to getting to the last header bolt?
Old Sep 15, 2004 | 09:38 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
Is there a trick to getting to the last header bolt on the passenger side towards the rear of the car? I am 6"4" and have big hands and i really have to try to get back there for that. Any tips would be great.
Old Sep 15, 2004 | 11:26 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've found that when using headers on a sbc I get the small head bolts-think they're 7/16" head on 'em. Anyways, if you use a crow foot you can get them as tight as you want- easily. You only get about a1/4-1/2 turn at a time and must reset the crow foot, but about the only feasible way to tighten them down.
For those that dont know what a crow foot is, simply put it appears you've cut the open end off a wrench and it has a spot to stick in a 3/8" drive extension or ractchet in. Buy the better brand stuff too as the cheaper china made wants to deflect/open up and will easily strip the bolt head.
Old Sep 15, 2004 | 02:32 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
stick out your tounge... squint one eye... and twist your nose to one direction... that should help some!!!
It is hard to get to... I had to get to mine from the bottom and it was still tough.
Old Sep 15, 2004 | 02:33 PM
cgb's Avatar
cgb
I use the small head header bolts as well. Much more room to work with all around.
Take a small box end or open end wrench the size you need and simply cut it down.....
I've got one specifically for this..it was a cheapy wrench, I just torched it and snapped it basically in half.
Then rounded the end with the grinder.
Old Sep 15, 2004 | 02:35 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I ended up finding a 3 inch open ended 7/16 at Home Depot I think... works really well.
Old Sep 15, 2004 | 09:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
the trick?....? its called PATIENCE
really though if you try hard enough and long enough you will eventually get it. i started at the back bolt and worked my way forward. that helped me install the 3 pairs of headers i have installed before.
Old Sep 16, 2004 | 12:28 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
from the bottom is the least stressful. you might have to drop the starter to get your hand up there, but you can at least get to the bolt.
Old Sep 16, 2004 | 01:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
3/8" header bolts.
the standard 7/16" head header bolts are too big to give you enough room.
also if you take a old wrench, and bend it in the middle so its curved, its easier.
Old Sep 16, 2004 | 01:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could always undo the motor mount bolt on that side and jack up the engine a little. It isn't too hard to do usually.
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
