opinions on these headers
Old Sep 15, 2004 | 03:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
http://store.summitracing.com/defaul...8721&x=16&y=10
what is your opinion? keep in mind i live in cali and i plan to stay emmissions legal.
so out of all the 50state legal headers available to my car, think this is a good choice?
Old Sep 15, 2004 | 03:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You should be able to pass with any header with AIR provisions. I would look at a set of TPI headers so that you don't pay all that money for a 2.25" y-pipe.
Old Sep 15, 2004 | 03:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
umm dunno where u got that from, that is the 3" tpi headers...:
Old Sep 15, 2004 | 05:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Better: http://store.summitracing.com/defaul...-2055&x=20&y=8
Old Sep 15, 2004 | 07:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Sorry I didn't look closely. You said it was one of the only kits avaialble for your car so I assumed you were looking at the TBI specific edelbrock headers. They come with the 2.25 y-pipe. Even still the overall design of the edelbrock headers is average at best. I would consdier the 2055's that five7 linked you to. There really isn't a better set out there. The only other ones that are smog legal and on a similar level of performance and quality would be the macs or SLP's.
Old Sep 15, 2004 | 09:29 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
The 2055 setup doen't include a y-pipe does it?
Old Sep 16, 2004 | 12:17 AM
five7kid's Avatar
Yes, it does.
Don't believe Summit website pictures.
Old Sep 16, 2004 | 12:30 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
the 2055's dont have AIR though, so thats out of the question.
Old Sep 16, 2004 | 12:32 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i just checked out the SLP set, too expensive for my wallet.
what are these 'mac' headers i hear of?
Old Sep 16, 2004 | 05:44 AM
five7kid's Avatar
Wrong. 2055's have A.I.R. And O2 sensor bung.
Don't believe Summit pictures.
Old Sep 16, 2004 | 05:46 AM
five7kid's Avatar
2055's have a CARB EO # tag welded onto the #1 primary tube. The application is '86-'90 TPI single cat vehicles. They have A.I.R. tubes/fittings, O2 sensor provision, and y-pipe to a 3" slip fit cat.
I don't see what you think is wrong with them. They're perfect for what you've got and what you need to comply with.
Old Sep 16, 2004 | 05:53 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
2460's don't have A.I.R.
Old Sep 16, 2004 | 08:46 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
listen to five7kid, those hooker headers are among the best for our cars that include a ypipe, the added benifit is the are 100% legal because of the air fittings and o2 bung, plus imo they have the best premade ypipe for our cars, i was gonna get some but i found a deal on ebay, and i dont need legal stuff, cause i dont live in calanaziornia.
in my opinion you have the edlebrocks the hookers and the slp headers, they are the 3 best looking ones, the pipe for the hookers is the best outta the three so go with hooker or go with your wallet, any of these are way better than your manifolds and will be fine with the stock motor, all three will support most any mods you make, well over to about 400-450hp, then serious exhaust systems benifit the motor more.
Old Sep 16, 2004 | 08:56 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
As five said you cannot go by the summit pictures. Just read the fine print and it even says picture may not represent actual product.
Here is a link to the macs. They are the only other header out there that have a y-pipe that matches the 2055's. Personally, I would go with the 2055's.
Mac headers
Here is a pic of the macs. I couldn't find a good pic of the 2055's but a you can search for that.
Old Sep 16, 2004 | 11:58 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok i think i may go with hookers then. second problem.
summit says they are not available. who else sells them?
and last question. can i get the hookers in a nickle/chromium finish?
Old Sep 16, 2004 | 12:25 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Contact ACS (site sponser) for the Hookers (coated). Also, thunder racing (site sponser) sells them along with Jegs.
Those links should take you right to where the 2055's are listed.
Old Sep 17, 2004 | 07:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i cant seem to find them in a chrome/nickel finish
Old Sep 17, 2004 | 09:09 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You won't. Coatings are done by another outside company. Therefore, you either need to buy it from them direct or sent it to them to have them coated. I would just buy them direct with a ceramic coating from ACS or jey-hot. Do not get chrome unless you want to watch it fall off over time. Ceramic coating is what you want.
Old Sep 17, 2004 | 10:45 PM
mgray10's Avatar
Car: z28
It is my opinion that the Edelbrock units are garbage considering what other pieces are available for similar prices.
I was dissappointed, after receiving my Hooker 2460 headers, with the construction of the Edelbrock headers. Before my new headers, I was only dissappointed with the exhaust leaks. I am sure someone can trace this down to my heads or gasket, though. (especially because the leaks were gone with the new headers)
I question whether those MAC headers are totally legal, meaning C.A.R.B. number supplied. The earlier the air is introduced to the exhaust, the more heat is present to aid in making new bonds, and the more time this has to take place.
If you are sincerely set on spending these smaller amounts of money,do not invest in coating.
Old Sep 17, 2004 | 11:23 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
The Hooker 2055's are definately totally smog legal, and are the best for our cars as a total package (headers and Y pipe) I would consult with ACS (link at the top of the page) they are really decent guys.
Trust me, you don't want a chrome header, they burn, discolor, rust through and flake. Nickel is even worse, it's a cheap incomplete chrome job, and even less durable. Go with the polished ceramic coating, it is thermally and durability wise WAY better and almost the same cosmetically.
Good luck
Troy
Old Sep 18, 2004 | 07:49 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Or just go with the SLP's which are stainless and don't worry about paying for the coating.
Old Sep 18, 2004 | 09:58 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Are the 2055's ceramic?
Old Sep 18, 2004 | 11:00 PM
mgray10's Avatar
Car: z28
No header is ceramic. Many steel headers are ceramic coated for look and function. Many of the header manufacturers sell ceramic coated headers for additional costs, though this is generally poor compared to those contracted by the header owner for coating by Jet-Hot and the likes.
If you need to save money do not worry, however, expect ugly headers, hotter underhood temperatures compared to manifolds and coated headers, ugly headers once again, and failing headers sooner than coated pieces. Depending on the weather in which the headers are used, the headers could last 5 years or 15 years, uncoated.
I plan on changing to long tubes before my coated pieces fail, and let's just say I am too cheap to buy long tubes right now.
Old Sep 18, 2004 | 11:09 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i figured youd know i ment ceramic coated. lol
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Jlanz55
Sep 8, 2015 11:28 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
