lt1 exhaust manifold
Old Sep 16, 2004 | 08:28 PM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
will the exhaust manifolds from an lt1 engine work in the 3rd gens... reason i asked is that i am doing an lt1 intake swap, and it seems that if i could use the manifolds since they have an egr tube comming from them i will be able to make the egr work on the lt1 intake with little modification.. just need to be able to get a pipe from the back of the intake to the manifold... since my p1 does not have the exhaust manifold with that provision and the lt1 exhaust manifold does i thought that if it fits , i could make it work.. thanks in advance for any help thanks
Old Sep 16, 2004 | 09:16 PM
85TransAm406's Avatar
Car: 1985 Trans Am
If you did that where would you put the distributor? the EGR valve would be in the way.
Old Sep 16, 2004 | 09:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
No they will not work.
Old Sep 17, 2004 | 06:13 AM
3rdGenSS's Avatar
thanks shifty, wasnt sure and couldnt find anything thru searches... guess i will go at it another way... maybe tap a hole for a pipe thru the manifold into where the 3rd gen egr comes in from the head and run a pipe to the rear of the intake... as for the egr valve 85 transam.. i was thinking of machining a block of aluminum to match up to the ports and have it come off at an angle to clear the dizzy... got to be a way to make it work though.. thanks again
Old Sep 17, 2004 | 04:11 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Yes they will bolt up, however your real problem is getting the egr valve to clear the distributor which is added. You'd need a custom y pipe though.
AussiePr0nCar
Mar 6, 2020 04:04 PM
anesthes
42
Oct 24, 2015 07:30 PM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
transaero
Aug 31, 2015 01:14 AM
