Need Help-lost on what to do next
Car: 89 bird, 86.5 D21 Hardbody duringwinter
Engine: 305, VG30e
Transmission: 700r4, dunno the other one :)
I bought these
Hedman Hedder #68470
2 months ago and I think im ready to put them on
They came with the gaskets and bolts, but im not sure what else I need
They need to have an o2 bung welded in and a hole drilled, is that a big deal to have someone do?
Also I guess I need a y pipe, im new to all this and have no idea what a y pipe is
I wanted to do I guess just a straight pipe from the headers to the back of the car, is that feasible?
I guess I need some help on what to do, the whole exhaust on there now i pretty much trashed (BAD rust) so what would be my best and cheapest option to get performance and decent sound to go with the hedders I bought?
Thanks guys sorry its so long
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
First off, the y-pipe is that y-shaped(hence the name) that connects to your hedders on both sides of the engine. I'm not sure if heddman has matching pipes for their hedders, if not you can have someone fab it for you and to weld in the o2 bung is not a big deal. So get the y-pipe(3"), a high flow direct fit 3" cat and a 3" cat-back of your choice...there are a lot of them to choose from and the prices vary. Get that plumbed up and you should be good to go.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Any exhaust shop should be able to put an 02 bung in your headers for less than 40 bucks. That includes parts and the welding and such. I believe those headers have a matching y-pipe that is sold separetly.
Here is a jegs part number for the y-pipe that goes with those headers. 500-17470
The y-pipe is the part of your exhaust that merges the headers to a single exhaust pipe routing. It looks like a y.
Engine: 305, VG30e
ahh I see
So is the ypipe the only option on these cars? (no clearance for two pipes?)
So how much do you think im looking at 140 bucks plus the cost of a straight pipe? How would I get that pipe all the way to the back of the car?...I dont need the cat
Any I guess cat-back kits?
Sorrry im asking dumb questions
thanks for the help guys
Car: '90 RS
Engine: 377 LSX
Originally posted by DustyWusty
ahh I see
ahh I see
