Need suggestions on exhaust setup for a 92 RS
Old Oct 10, 2004 | 03:00 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i'm a student at wyotech right now and at the end of each six week phase i get 3 days to use the shop to work on my car. i was thinking the first thing i can do is the exhaust. i was thinking of either redoing the stock/current one (it has dynomax mufflers) or installing electric cutouts, or both. my questions are:
what setup/brand should i run for the best performance with a good mix of sound quality?
i also have a catalytic convertor that is all rusted out, should i replace it or just gut it?
would it be better to run just a longtube setup or electric cutout?
should i run a stock style (with mufflers) exhaust setup or go for a more true duel setup?
what type of headers (long/short & what size) should i get?, i've heard of people having problems installing longtube headers.
i was planning hooking everything up and then having a shop weld it all together to make it air tight.
Old Oct 10, 2004 | 07:44 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
For your car, I would run shorties. No point in suffering ground clearance or torque (from what I hear) with longtubes on a 305, unless you have some serious HP. Most people just suggest shorties and a good 3" cat-back. Probably the best headers you can get are the Hooker 2055s (Jegs has them). You can gut the cat, weld in a straight pipe, or get a high-flow cat, it's really up to you and if your state has emissions or not. High-flow cats only cost $50 to $100 anyway. As for a cat-back, I would just stick with any decent 3" system (Hooker seems to be popular for this, too).
Old Oct 11, 2004 | 03:44 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Another vote for the 2055's. The only other headers I would consider for your set-up would be the macs (very close to the 2055's) or the SLP's. I would then purchase a TPI cat-back of your choice and buy a universal 3" cat since you can have all the fab work done yourself.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
formula_novice
Sep 5, 2015 03:58 AM
downsouthboy
Aug 29, 2015 11:29 AM
drathaar907
Aug 6, 2015 04:20 PM
