AFR and SLP??
Old Nov 15, 2004 | 11:53 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
AFR and SLP??
Old Nov 16, 2004 | 12:52 AM
92GTA's Avatar
Good question. I'll be installing new AFR L98 angle plug heads in a few weeks and using my SLP 1 5/8" Tri-Y's...
Old Nov 16, 2004 | 01:56 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i ran slp 1 3/4 and the only issue i had with them was plug #5 and # 6 were a biatch with the way the tubes run besides that they were a great header and never had much leak issues. put hooker 1-7/8 longtubes on my car and have had all kinds of probs, almost want to go back to the slp's
Old Nov 16, 2004 | 02:46 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
From what I understand you will not have issues if you got the L98 angle heads. From what I have read the problem occurs when people went with the standard angle plug heads and not the L98 angles. There used to be a thread that went into in-depth detail about this.
Old Nov 16, 2004 | 02:59 PM
i think you are correct , this was on a set of gm fastburns
Old Nov 16, 2004 | 10:38 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
