Just for the Track
Old Dec 7, 2004 | 03:37 PM
mean83z28's Avatar
Car: Blk 83 Z28
Engine: 355 c.i.
Transmission: muncie 4-speed m21
Just for the Track
In the past I have been able to unhook my crappy stock exhuast from the y-pipe. I have no cat so this is no problem, I just drilled a hole where the slip fit of the two pipes overlap(so there is no leaking when hooked back up for the street) and when I pull the system off of the y-pipe I can mount the disconnected pipe to the side of the y-pipe to hold it up from the ground. Now I have open exhaust from after the y-pipe. Do you think this helps me, or do you think I should leave it hooked up? The problem is, the rest of the system on back is still the stock one pipe to two split, that Chevy so terribly rigged.
Old Dec 7, 2004 | 03:59 PM
sprayedcam86's Avatar
Car: 86 camaro z28
Engine: wild 355 chevy sprayed with nos
i would leave it hooked up as long as you dont have a muffler. you need some back pressure.
Old Dec 7, 2004 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would try it both ways and see which works better.
The amount of backpressure "needed" for a properly tuned carb'd engine is "nil".
Old Dec 7, 2004 | 06:49 PM
mean83z28's Avatar
Car: Blk 83 Z28
Engine: 355 c.i.
yeah i was planning on trying it both ways. Looks like I ran outa time with winter here and all, my local track, Cecil County, shut down for the winter a couple weeks back. Do you think that a 3.5 inch Mufflex system followed by a Spintech would be my best bet? I plan on getting more power out of it by this spring, so I think exhuast should definately be first before I do anything more to it. I think its really being held back by that little pansy pipe splitting deal. Also, for the winter adding some real headers, I guess hedmans, mostly cuz of the price.
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
