Useing a inlet pipe as a outlet?
Old Dec 9, 2004 | 05:22 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I bought a muffler for 20 it looks like a flowmaster but its called RAVEN.Anyway both outets are on the smae side and the inlet is on the other side.I want to keep the boom tubes on my car.Would it be ok to use one of the outlets as a inlet and use the inlet to run the other dual?
thanks heres a pic
Old Dec 9, 2004 | 07:08 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
the ravin muffler is a midas brand muffler (cheap) and the one you got i believe is made for truck, iirc thats how the truck mufflers came one inlet, and two outlets on the same side. you can run it the way you stated, but i wouldnt reccomend it, the flow of the air would just cause all kinds of trouble, and you would probably lose power.
Old Dec 9, 2004 | 07:48 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
https://www.thirdgen.org/techbb2/att...postid=1907926
would doing this work?
Old Dec 9, 2004 | 08:58 PM
QuickStyle's Avatar
Car: 91 Z28
yes that would work, just make sure you install it in the intended direction of flow
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
toronto formula
Nov 10, 2015 06:17 AM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
tmellott89
Aug 16, 2015 02:58 PM
