removing smog pump
Old Jan 23, 2005 | 03:27 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
removing smog pump
alright i got a 91 trans am gta mostly stock. i herd if ya remove the smog pump it would give ya a little extra power and wouldnt hurt ur car. so if anyone can guide me the right way to remove it or send some pics it would be great. i prollie know that this question has been asked but i cant find it.
Old Jan 23, 2005 | 03:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It won't give any more power.
It may not hurt the car.
Certain TPI systems assume the presence and operation of the A.I.R. in the PROM tables.
Old Feb 9, 2005 | 07:48 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
it really wont do much for power...but if you remove the pump and all the hoses and such for sure you'll have a cleaner lookin engine....i did the same cause smog pump went out...and now....A question to anybody who can answer ....once smog pump is removed will the EGR valve and pcv valve still funtion ? im not really sure myself but would like to know
Old Feb 10, 2005 | 08:12 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
There's a tech article on the main page about removing the smog pump: https://www.thirdgen.org/newdesign/t...rpentine.shtml
Yes, they will still function properly.
Old Feb 14, 2005 | 01:06 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Trash the pump
I highly recommend getting rid of the smog pump just because that is one less thing to fail on you. I was at an autocross race 5 hours from home when my smog pump seized up. Thankfully I had enough tools to rip out the **** inside that caused it to seieze.
When I got home I went to the store and found a belt that would route around it. There is an article here that tells just how to route around the pump.
Bottom line, unless you are a tree hugger get rid of it.
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
