Y-pipe question
Old Feb 5, 2005 | 08:45 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Y-pipe question
Doesn't someone make an aftermarket y-pipe for use with the stock manifolds, that's better than the stock pipe? I thought it was SLP, but their web site doesn't show much for thirdgens.
Ideas?
Old Feb 5, 2005 | 09:06 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Not that I know of.
Old Feb 5, 2005 | 10:13 PM
anondude13's Avatar
Re: Y-pipe question
Ideas?
You can buy the slp y-pipe separately from their header kit if you call them. I'm not sure if it will fit on to stock manifolds though (I'm pretty sure it won't). You might as well just go headers and y pipe IMHO.
Old Feb 6, 2005 | 01:42 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
MAC makes one, but honestly, i would just go with a set of header too, doesn't make any sense when the manifolds to flow for crap.
Old Feb 6, 2005 | 08:41 AM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
http://www.fbodymotorsports.com/inc/...l?v=1&pid=7530
Old Feb 6, 2005 | 12:29 PM
onebinky's Avatar
I have the hedman Y pipe on my car, but I also have their shorties. I believe the headers exit in the same place as stock, and they have the ball flanges on them. But like it was said, it would be pretty pointless to upgrade the Y and not the manifolds.
Old Feb 6, 2005 | 04:55 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
If you are trying to keep a totally stock appearing look but still want performance improvement that is the way to go. Those things flow substantially better than the stock Y. The stock pipe is more of a T than a Y pipe and its only 2 1/4" into 2 3/4" where this is 2 1/2" to 3" with a nicely joined Y.
Old Feb 7, 2005 | 02:55 AM
Tremo's Avatar
Kewl Joe, thanks for the link. Does that y-pipe have an O2 sensor bung?
Old Feb 7, 2005 | 08:09 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
SLP makes a slew of y-pipes that are meant to retain the stock iron manifolds. Pointless though.
Old Feb 7, 2005 | 08:49 AM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Im 99% sure the O2 sensor is in the manifold itself and not the Y pipe.
Old Feb 7, 2005 | 09:49 AM
anondude13's Avatar
Yeah it's in the driver's side manifold.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Sep 8, 2015 03:38 PM
downsouthboy
Aug 29, 2015 11:29 AM
Out-Cast
Aug 22, 2015 07:49 PM
redmaroz
Aug 16, 2015 11:40 PM
