turbo V6 camaro exaust
Car: none yet :(
Engine: none yet :(
Transmission: none yet :(
i'm looking at doing a turbo set up on a 2.8L would it be good to have a 3" dual exhaust or more like dual 2.75"
From what I've heard, you can't go too big after the turbo. So keep in mind that you probably won't need more than 3", but don't go too small. I'd also definately stick with single exhaust as you are going to have a single turbo, and that just keeps things from being unnecessarily complicated.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Originally posted by TS21
oops i ment twim turbo useing too eclips turbos and inter coolers (also 2 of them) so then what 2.5"?
I've seen a 3.8 turbo buick swap running through a stock 2.75" running low 11's/high 10's all day. I'm sure that a single 3 or even a stock 2.75" will work fine for you
Car: none yet :(
Engine: none yet :(
Originally posted by GTA matt
Just FYI, a stock 2.8 will not take a whole lot of boost before she blows. If you do manage to pull off a TT setup, dual 2.5's would be more than adequate.
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
the 3.1 turbo in the Grand Prix ran (IIRC) 5-7 PSI, people have gone up to 10-12 on stock internals. not that it's a good idea...
building a V6 to take boost is quite simple, check out this link..
http://domesticcrew.com/660board/viewtopic.php?t=20
he's running about 250-260 crank HP, i think he's in the high 13's with it. keep in mind that it IS a daily driver as well.
and yes, that is a FWD gen 3 top end on a RWD gen 2 block, i think he's even using the MPFI / computer setup from a 2nd gen V6 Z24.
Engine: L98/383
Axle/Gears: 9"
And that dude in your link has WAAAAY to much time on his hands. That's pretty cool though.
Engine: 450HP 355
Transmission: TH350
on the contrary, the 3.1 turbo has slightly lower compression than a stock FWD Gen 2 3.1, other than that, it's got the same exact pistons, stock rods, etc. there is essentially nothing special except for the pretty plenum and lower compression and (rumor) a slightly different cam grind (and turbo of course)
*edit, that's the FWD aluminium head 3.1's i'm comparing to, not the RWD Iron head version*
a member of V6Z24.com contacted Mclearan and discussed the specifics about the engine with them. they did not use forged pistons because of the low boost involved. Several of us V6 guys have swapped those engines into 2nd gen Z24's.
they are one great engine, a buddy down in Texas took his a little further and is on track for high 11's this year: www.turboz24.com
he's got some stuff in there on the TGP engine as well..
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Andrew Prakash
Sep 8, 2015 11:48 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
