Problems with my new exhaust
Old Mar 11, 2005 | 02:41 PM
anondude13's Avatar
_
Old Mar 11, 2005 | 03:44 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Sounds like catalytic converter is possibly in little pieces. Might be parts of it in your muffler.
Old Mar 11, 2005 | 04:30 PM
anondude13's Avatar
I don't think that would be consistently temperature dependent.
Old Mar 11, 2005 | 05:08 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
I think those mufflers use the preforated tube and glass filling like a Dynomax or Magnaflow. Its possible that the insides of the muffler are coming apart. When the metal gets hot and expands it might be moving around. On a side note, since I put my American Thunder system on my car, it makes the heat sheild for the gas tank rattle. I know thats not a heat generated noise but it could be a possibility.
Old Mar 11, 2005 | 07:09 PM
anondude13's Avatar
I thought about that but it appears to clear the shield. What are people's thoughts on retrofitting a different crossflow onto the 5672 piping if the muffler is indeed bad?
Old Mar 11, 2005 | 07:38 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
I absolutely love my Flowmaster 53083 crossflow. Its not the usual one you hear on these cars. It has a much deeper meaner sound than the standard 80 and it won't fall apart on the inside.
Old Mar 12, 2005 | 11:34 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
Hmm it is in the actual muffler though? Only issue i have is under high rpm like on startup or under a load my back window rattles...could be 3" with no muffler and a high flow cat though
Old Mar 13, 2005 | 12:12 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
The only difference between the two are length, width, and thickness. Both have the same internals, I don't see how they would sound different
Old Mar 13, 2005 | 01:33 AM
anondude13's Avatar
I'm definately not a fan of the flowmaster sound (or most baffled mufflers). I'm gonna bring it to a trusted shop here in charlottesville and have them find it. If it's the muffler I'll get a replacement edelbrock or another glasspack crossflow. If anyone has experience with metalic rattle sounds that develop as the car gets hotter please let me know. Other than that thanks for the input everyone.
Old Mar 13, 2005 | 09:49 AM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
53083 has the same insides as a 70 series big block muffler. Don't know how they configured it to crossflow but when you look into the inlet there is one of those small tubes that flow into sound deadening chamber and the actual exhaust gas flows down the center of the muffler to the V baffle at the other end.
Street Lethal
Apr 30, 2019 12:14 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
