headers
Old Mar 3, 2005 | 04:37 PM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
headers
i am thinking about hooker 2210s for my 355.some of you say they will fit right in some of you dont why?i was thinking about hedman but with 400hp i would rather go with hooker.i will be running duals i have air shocks and 29 inchs in the rear . is there going to be a starter problem?
Old Mar 3, 2005 | 07:02 PM
sellmanb's Avatar
Car: '86 Berlinetta
You may experience heat soak with some y-pipes. The SLP setup with the 1 3/4 headers will probably work out great for someone looking to make 400hp. If starter is your concern though, and you dont want to chance it (since you'll have to take your y-pipe off from now on to take out your starter) you should just buy a mini-starter from somewhere. The LT1 mini starter seems to work well and is an over the counter part. Or you can get a nice expensive one as well that will probably last a bit longer.
Old Mar 3, 2005 | 07:17 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my father and i both have the hedmans, they will handle 400hp EASILY! my dads car is a 355/powerglide/4.56 combo and runs 11.5-11.7
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
