headers
Old Mar 4, 2005 | 03:31 PM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
headers
there arent many mechanics where i live so i have to make it the easiest.i see alot of pics on duals and headers i would like to go with 2210s but it seems that they are lower than most,below the trans pan i see some that go above it.i have a 355 and its going to be a daily driver car these ones i see above are they heddman?
Old Mar 5, 2005 | 11:21 PM
Derek_91's Avatar
Car: 2002 Camaro
Axle/Gears: Stock 3.42
The 2210's are Hooker super comps i beleive which are 1 3/4". Headman LT part number is 68460. They are 1 5/8". I had a set of these. With Auto trans Headmans will fit great. They tuck right up to the body so there is no clearance issues. If you going to shorties i just installed a set of 68470 which fit great also. Im sure there will be others that comment on this issue to but i thought i would just give my 2 cents.
Old Mar 6, 2005 | 05:54 AM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
thanks derek,after i posted that thread i went into heddman.com and was looking at the differance between the painted and coated it coated ones looklike they have a much better bend to them.im going to go with the coated heddmans still cheaper than 2210 painted.thanks again
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
