Y pipe
Old Mar 11, 2005 | 04:23 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
Y pipe
Does a 3rd gen camaro have enough clearance to have a 3 in y pipe put in instead of the stock one?
Old Mar 11, 2005 | 05:05 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
3" before or after the Y? MAC makes a stock 2 1/2" into 3" Y that fits the stock manifolds.
Old Mar 11, 2005 | 05:36 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
before the cat
Old Mar 11, 2005 | 05:52 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Headers or stock manifolds? Stock manifolds can't accept 3" pipe. Even if you run headers 3" is gonna be too big to start out with. You need to go headers into 2 1/2" pipe and then Y into 3 or 4".
3" is a waste of pipe unless you are pushing 500hp.
Old Mar 11, 2005 | 11:17 PM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
thanks for the advice..guess i will just get a 2 1/2 then if the 3 would be a waste
Old Mar 12, 2005 | 02:52 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Yeah, using 3" right off the headers is gonna make the engine work to hard to push the exhaust out just as if you are running too little pipe. Too small of a pipe and the engine can't get all the gas out, too big of pipe and there isn't enough pressure to move the hot gas through the pipe.
Old Mar 13, 2005 | 11:58 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
Re: Y pipe
to answer your original question, yes there is enough clearance. check this out:
https://www.thirdgen.org/techbb2/sho...hreadid=283060
i wouldn't use it on a stock or mild buildup but if you are pushing some power, yeah it's a cool idea.
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
