what effect does NOT having AIR tubes attached to cats have?
Old Mar 12, 2005 | 03:32 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i was just wondering (until i figure how i'm gonna do it) what effect does it have, short term or long term, if i don't hook up the tubes that go to the cat converters. (the ones that come off the AIR system) seems like all that thing does is blow air out of it and in to the cats, so what does it really do? and, no, the car is NOT inspected for emmissions...
KAM
Old Mar 12, 2005 | 04:00 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
all the Air system does is to pump air into the cats to help bring them to operating tempature faster ( 600* F ) that way the cats are funtioning properly as the car enters closed loop.
Old Mar 14, 2005 | 01:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's not quite right. The A.I.R. is routed to the manifolds until the system goes to closed loop. The flow is then routed to the cat. It provides more oxygen to aid in the conversion of CO to CO2. Its purpose is to lower emissions. Not having it hooked up will raise the undesirable emissions your car produces.
Old Mar 14, 2005 | 05:41 PM
1984HO's Avatar
Car: 1984 Z28
well said five7kid.
i was assuming that he was removing the entire engine managment system and in that case the air system would be inactive already so removing the components would not pose a problem other than a belt rerouting.
Old Mar 15, 2005 | 10:18 AM
Car: '91 Z28
Axle/Gears: 323's
so short term not being connected doesn't harm anything, other than undesireable emmisions. another question that i've asked before is what type of tubing to use and someone said silicone rubber, but the place i know of to get different kinds of tubing and hoses doesn't have a clue, so i would like to use a flexible type tube and was thinking maybe heater/ radiator hose?
KAM
Old Mar 15, 2005 | 11:18 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Would you believe when I got my gta someone had used a piece of garden hose and ran it to the cat. Some people.......
Laters,
Conrad
Old Mar 15, 2005 | 12:02 PM
Car: '91 Z28
Axle/Gears: 323's
Laters,
Conrad
yea, i'd believe that. so if i used heater hose, i wouldn't feel so "ghetto". at least, in a high-temp wrap, it would look good...
KAM
Old Mar 16, 2005 | 02:01 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
1/2" OD copper tubing and 1/2" compression fittings
Old Mar 16, 2005 | 07:02 AM
Car: '91 Z28
Axle/Gears: 323's
thanks.
KAM
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
86IROC112
Sep 7, 2015 01:37 PM
chazman
Aug 22, 2015 02:01 PM
drathaar907
Aug 6, 2015 04:20 PM
