So to 3" or 4"?
Old Mar 13, 2005 | 03:06 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
So to 3" or 4"?
Well I am trying to deceide if i should spend the extra dough on the mufflex 4" exhaust. What do u guys think? Here is my engine set-up:
406ci
10.5 compression
AFR 195cc heads
solid roller cam 242/248 5.71/.577 @ 0.50
Hooker LT's
T-56
12-bolt with 4.10's
In the very close future i am going to put a 150/175 shot of nitrous on it. Is the 4" going to be worth is to me? Or should i get one of the better 3" kits like that one that says it flows with-in 99.9% of a straight pipe? The car is a week-end car with some track duty too. But just for fun. thank you
Shawn
Edit the 99.9% cat-back I am talking about is the STR one.
Old Mar 13, 2005 | 03:12 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
spend the extra dough and get the 4".
Old Mar 13, 2005 | 03:42 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
A good 3" will be fine.
Old Mar 13, 2005 | 05:59 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
properly done dual 3" will do it IMO
Old Mar 13, 2005 | 09:38 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
A single mandrel bent 3" system with a mufflex or equivelent y pipe and a straight thru free flowing muffler is all he needs. I have a similar set up to him only a 383 and a slightly larger cam. I use a mufflex y pipe with a single bullet in the intermediate pipe then the axel pipe and tail pipe. I pick up only 1 mph going open exhaust.I also originally had this motor in a 1980 z28 with dual 3" and an x pipe and went the same as this current firebird with open exhaust.
Old Mar 14, 2005 | 08:05 AM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
What kind of fwhp do you think the car is going to make?
Old Mar 14, 2005 | 08:45 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
A strong 406 needs a 4" exhaust - no 3" is gonna cut it. If you want to save $ and weight, you can go with a 3-1/2".
Old Mar 14, 2005 | 02:57 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
My question is how much are we talking to lose? I mean is it 8hp or 40? I know the ATR is one of the best 3" cat-backs out there. The car may be a weekend car but i don't want it to be over the top in terms of loudness.
Old Mar 14, 2005 | 04:06 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I used to think the same way until I actually took my car to the track and found out it was still very close to my old car with the dual 3" system. If I can run hi 11's @ almost 120 thru a single 3" pipe so can he.Its all in the y pipe and muffler.
Old Mar 14, 2005 | 09:41 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
well i love my 4 inch mufflex with a spintech muffler... i have a mild 355 dont know hp numbers but flow's great and sounds awsome
Old Mar 14, 2005 | 11:00 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have a similar setup as you and went with the 4" mufflex kit with dual tip spintech muffler. You will not be dissapointed. Please don't believe the 3" single pipe is good enough for a 406 and nitrous. With my old 350 it went 8.52 through the 3" kit and when I uncapped it the car went 8.06. Backed this up twice. The 3" kit on my car wasn't even optimum for the 350 much less the 406. I went 6.95@100.82mph with my 406 and a 125 shot on dot tires and through the mufflex exhaust. I don't have as much cam or gear as you either. These are 1/8th mile times. This is actual experience not just an opinion.
Old Mar 14, 2005 | 11:54 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Yea this seems to be a very divided topic, my next question is: I smufflex the only company that makes 4" exhausts for our cars?
Old Mar 15, 2005 | 06:08 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Its not the 3" pipe that was holding you back . Most likely it was the muffler. I picked up about .3 taking off my flowmaster and putting on the bullet.
Yes I think mufflex is only company with a 4"system.
Mine too.
Old Mar 15, 2005 | 03:27 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I was looking at the magnaflow cat-back with the single in dual outs on one end muffler and one tail-pipe loops around. Do you think that will be a pretty good muffler?
Old Mar 15, 2005 | 04:51 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I believe thats the muffler that TRAXION had on his old iroc and it worked very well. I think he was running 11.6@117 on street tires.Its advertised as a straight thru muffler so I think it would work out real good. I was even thinking of giving it a try.
Old Mar 15, 2005 | 09:41 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I too had the flowmaster. I agree that some must have been the muffler because flowmaster just doesn't flow. Bottom line is that if he has a 406 and nitrous the 3" just won't let all of the potential power be unleashed. He definitely won't get hurt by getting 4". On the other hand if he does go ahead and get the 3" system and it doesn't perform as expected then disappointment will set in and he will eventually upgrade to a 4" system. Why not just do it right the first time and be done with it?
Old Mar 16, 2005 | 05:59 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I agree that a 4" system would work for him , but the mufflers that come woth the kit are still chambered.There was a thread a long while back about this topic and one of the posters had a 600+ hp motor that dyno'd better with a single 3" borla system than the 4" mufflex system. I think with a straight thru 4" muffler it would have been different, but also annoyingly loud since the only 4" straight thru desing mufflers I've seen are race only and don't really do much muffling.
Old Mar 16, 2005 | 07:27 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Yes I have been talking to someone on camaroz28.com and is running the magnaflow cat-back and a cut-out. He said he gained no RWHP with the cut-out open. His car dynoed 574 RWHP BTW.
Old Mar 16, 2005 | 07:53 AM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
3" dual or 4", it's not going to be a very noticeable difference. In fact, too little backpressure *may* effect power. The engine's power is from heat. Not fire, not gasoline, not oxygen, not an explosion (because it burns, it doesn't explode).. Heat. A certain level of backpressure is actually good because it helps keep heat in the combustion chamber. I'm not saying 4" is going to be overkill, but in a 406 it's not going to be a token either.
Old Mar 16, 2005 | 11:24 AM
mw66nova's Avatar
Engine: 7.0L
AHHHH! BACKPRESSURE IS ALWAYS BAD!!!!! what your thinking of is scavaging. scavaging helps pull the air out of the cylindar, and increases velocity.
Old Mar 16, 2005 | 02:21 PM
paul_huryk's Avatar
I just wat to point out that at tracks like Englishtown that monitor noise (on certiain days), they look under your car. If the muffler is chambered, you race, if its a bullet type or glasspacks, you don't race.
Old Mar 16, 2005 | 04:13 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
The magnaflow is not a bullet or glaspack type of muffler
Old Mar 17, 2005 | 05:49 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
except it looks like one...
go with the 4"....
