Which y-pipe?
Old Mar 28, 2005 | 07:17 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Which y-pipe?
Which y-pipe is needed for the :
hedman 1 5/8 Long tubes?
Part #: HED-68460
I know i'll need an off road y-pipe but I don't trust the exhaust shops around here enough to make one and have it routed correctly, they'll cut corners and what not.
Old Mar 28, 2005 | 08:36 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
there is not one available. most people who run these headers use the hedman universal X-tensions and then run true duals, but there is no reason you couldn't run the X-tensions and then some mandrel bends to a flowmaster 2 1/2" in 3"+ out. either way, it's gonna be custom and it's gonna reduce ground clearance alittle. here is a pic of the ground clearance on my cars, right at the X-tensions (which will be your lowest point). obviously this is a true dual setup, but it will show you what yours would look like. where my h-pipe is, just put your mandrel bends and y-junction.
oh, this car has v6 springs up front and no spring isolators in the back with factory v6 springs out back and a 28" tall tire.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
