o2 sensor placement
Old Mar 28, 2005 | 10:12 PM
83crossfire's Avatar
Car: 83 firebird, 95 tahoe
Engine: crossfire 305
o2 sensor placement
on a 350 tbi with long tubes, is it necessary to mount the o2 sensor in the y-pipe where the exhaust meets or can it be mounted in the collector of one bank. the 02 sensor is a three wire sensor. thanks
Old Mar 28, 2005 | 10:25 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
From the factory, it was only in one bank.
Old Mar 28, 2005 | 10:32 PM
on a lot of cars yes, but on this it is placed just after the two banks connect in the y-pipe. if it doesnt make a difference, then i will just weld the bung on one collector, just wanting to make sure since the factory one is after the y.
Old Mar 28, 2005 | 10:36 PM
Dewey316's Avatar
Car: 1990 Camaro RS
What car is it on?
I would imagine you will be better off closer to the motor, although the 3 wire is heated, so keeping the sensor warm is not so much of a concern.
Old Mar 28, 2005 | 10:58 PM
its on a tbi tahoe. i was worried about possibly not getting a good reading off of one bank alone, but on the other hand my bird has an old school o2 sensor on one bank and seems to work fine. thanks dewey
Old Mar 28, 2005 | 11:04 PM
i was also thinking of having two bungs welded on, one for the o2 and one for the wide band. a wide band would need both banks to read correct wouldnt it?
Old Mar 29, 2005 | 11:33 AM
Ronny's Avatar
my 02 is just after the collector in ext pipe. the WB is mirror image on other side. compromise. when i need to will pull plugs and compare banks. when i had xram 6 of 8 were perfect and 2 were rich. that was a compromised distribution as far as manifolds go. dont think my holley will have those issues?
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
