exhaust manifold leak
Old Mar 30, 2005 | 09:51 AM
wpaskar's Avatar
Car: 1985 2.8L V6 Camaro
Engine: 2.8L V6 multiport
Transmission: 4-speed automatic
I own a 1986 V6 2.8L Camaro that is my first car and is in decently rough shape. I use the car to get places, such as work, but I am hoping to also use the car as a way to learn about cars. My ultimate goal is to gain a working knowledge of car repair and restore my car while at the same time powering it up (possible V8 transplant in the future?). Anyways, my car is very loud and I have been told this is due to a leaking exhaust manifold. My question is, how hard is the manifold/gasket to replace. Can a rookie like me do it myself with the proper tools, or is it somethign best left to an expert?
Old Mar 30, 2005 | 01:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It isn't too hard. You should be able to handle it with basic hand tools, assuming you don't break off any rusted bolts.
I'd suggest you determine first exactly where the leak is. You may find you've got a rusted up or rusted off pipe, rather than a simple gasket blow-out.
Old Mar 30, 2005 | 05:00 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
yeah, Id find the leak first, Ive seen quite a few cracked manifolds, mostly the driver side.
Old Mar 30, 2005 | 05:34 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Maybe you just need to tighten the manifold bolts? I know with IROC's atleast, there were no manifold gaskets out of the factory. I'm not sure if the 2.8's got them or not.
Old Mar 31, 2005 | 09:04 AM
wpaskar's Avatar
The leak is right where the headers and manifold meet, making me beleive it has something to do with the gasket or at least a loose connection.
Old Mar 31, 2005 | 01:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Then it might be a warped manifold or a loose bolt issue. Either way you 2.8 dident come with gaskets from the factory so getting a gasket set would improve the chances of sealing. Last time I checked most of the parts stores dident have a listing for the 2.8 gaskets at leat for a 86 S10 but I do know they have them for the newer 60* engines so if all else fails tell them it's a 95 with a 3.4L.
Old Apr 1, 2005 | 07:54 AM
wpaskar's Avatar
Thanks, I'll check it out.
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
