My Car Smells
Old Apr 2, 2005 | 12:45 PM
ravix's Avatar
My Car Smells
'88 camaro
305 TBI.
As the topic says, my car is stank! In the last few months, it simply hasn't been running right, and one of the side effects is extremely pungent exhaust. As I drive down the freeway, my friends cars 10 cars back with their windows up can smell the fumes from my car.
Other symptoms of my problem:
-Lower Gas Mileage than the norm
-My car lugs at low RPM's in high gears. Moreso than normal (I can rarely use 5th gear)
-Overall less power than I used to have
-Over double allowed emisions (I got a waiver after a mechanic wasted $150 of mine)
The car has a highflow, functioning, cat that I put in myself, and no exhaust leaks. Good compression in all the cylinders. It usually runs at about 170degrees. I think it may be running very rich, but I don't know how to remedy the problem.
Any ideas?
Old Apr 2, 2005 | 02:05 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Looks like you're about due for a tuneup.
spark plugs, wires, cap & rotor, oxygen sensor, fuel filter, air filter, fuel injector cleaner, clean your IAC
look into buying a new catalytic converter also.
Old Apr 2, 2005 | 02:06 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
oh, you have a new cat. my bad.
when attempting to pass emissions, replace the thermostat with a stock 195 degree one, because higher temps burn cleaner.
bryan623
Mar 22, 2021 06:43 PM
maroe624
Apr 16, 2017 08:29 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
