suggestions on how i could get clearance for my true duals
Old Apr 2, 2005 | 04:52 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
i got a 87 z28 with the true duals with no cats str8 piped to the passneger n driver sides to 2 turbo mufflers they hang real low n i always gotta be careful when i dirve it right now i i have the stock camaro 15 inch rims n i have a set of 4th gen 16x7 rims goin on will that help out a bit or should i get higher springs for the rear?
Old Apr 2, 2005 | 08:18 PM
klumb15's Avatar
i doubt it will make a dramatic difference, the only way it will make a big difference is if you are able to run a big meaty tire out back...how come they are only 16x7's? you can't fit a very big meaty tire on that! also, you know you have to get spacers to make a 4th wheel fit dont you??? you said your exhaust is side exit? have any pics, i'm debating if i should go side exit or not...i'm lowered like 1.75", so i'm kinda scared...
Old Apr 2, 2005 | 10:50 PM
MoroteZ28's Avatar
i already got the spacers 2 " i had them on my 84 z28
Old Apr 2, 2005 | 10:51 PM
MoroteZ28's Avatar
ill take pics of it soon and ill post them up
R13_Braz
Sep 18, 2015 05:00 PM
jer4251
Sep 16, 2015 11:29 AM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
