Pipe Question
Old Apr 4, 2005 | 12:17 PM
Strunthopht's Avatar
Pipe Question
I have an exhaust leak and I'm pretty sure that it's comming from my Y-PIPE. I'm a completely stock setup.
Sometime in the future I'll be getting headers (shorties).
My question is, if I stayed with stock manifolds and wanted my Y-Pipe to terminate into a 3" pipe and go through a 3" High-Flow Cat but stock pipes after the cat (basically just the Y and the Cat will be changed at this time and later, Headers, Muffler and way in the future, cat-back piping) can I just use sizers (or whatever they're called) to go from my stock manifold to a bigger diameter pipe down to the cat-back piping, or will I lose a lot of power or create a lot of back-pressure or something? All I'm trying to avoid is buying a Y-Pipe now to fit manifolds and change it later when I go for a 3" header-back system.
Old Apr 4, 2005 | 01:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
SLP makes a direct fit y-pipe replacement but it is costy. You are better off trying to patch and or fix the leak while you save for headers. You can go the route you mentioned but all the reductions and such you create will make for a lot of work.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
