big cam exhaust system shakes
Old Apr 7, 2005 | 08:11 AM
scooted45's Avatar
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
I've got a bumpy cam and at 1000rpms it lopes so much that the cat smaks the heat sheild. It's really anoying. Is there a nother hanger I could install? Or should I just turn my idle up higher?
Old Apr 7, 2005 | 03:26 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
those heat shields are worthless. Replace it with something stiffer or pull it off if it bothers you that much. Don't turn up your idle for something like that. Fix the PROBLEM not avoid it.
Old Apr 8, 2005 | 12:33 AM
scooted45's Avatar
I dunno is there a way to tighten the system w/out making it too ridgid?
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
cstrobel65
Aug 15, 2015 10:19 AM
makaveli09
Aug 12, 2015 09:07 PM
