What Should This Cost?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey guys, just a question...
Recently, I got myself a Hooker catback for my Z28, and I have a set of Hedman headers, Y-pipe for said headers, and a 3" cutout I'm going to have installed when I get the Hooker system.
Now, this is what I want to know... My system will not be able to just bolt together at home, since I cut off the 2.5" pipe on the Hedman Y-pipe so I can run a real 3" system. So what I want to have done, is have a 90* piece of 3" pipe bent to go from the Y-pipe to my cutout (where the cat used to be) and then a 45*-or-so peice from the cutout to my Hooker system.
What do you think a job like this should cost? I'll be installing the headers and Hooker system in the car (the catback will be tied up) before I take it to the shop. I just basically want them to stitch the whole thing together for me.
Any ideas, roughly, what this should cost me?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i don't see why it would cost much more than $50. if you take in some mandrel bends which would flow better than the crimp bent pieces most shops have (cause most exhaust shops don't have a mandrel bender) than it would probably cost less. even less if you mocked it up and all they had to do was zap some welds on it.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The bends arent too drastic... the 90* peice I need would be a very wide bend, not a sharp bend. Same with the 45* peice.
One shop I talked to does have a mandrel bender that will do 3" pipe. Would this be expensive to have the peices made?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Time should be under an hour but, 90% of all places will charge for an hours labor even if it isn't. Call locally for hourly rates.
Alot of people also confuse mandrel benders with die (pinch) benders. It's ultra rare for a standard shop to have a mandrel bender due to cost and generally you'll need someone that costs more than $6-8/hr to operate said expensive equipment. Not to say they aren't aout there.. it's just super rare since it's not cost effective to have for general exhaust repairs. Hell.. OEM doesn't even used mandral bends..
If I were to take a wild guess, you're looking at $150ish (US). Most places are $$55-75/hr (where I live) plus about $40 for a straight stick of pipe (you'll buy the whole thing even though you're not getting but a few feet) plus clamps and/or flanges + misc.$ for the slapnuts to screw things up before everything lines up good enough to call it done.
Just my opinion though.. it's been awhile since I've had someone else work on anything I've owned.
Originally posted by deadbird
If I'm understanding correct, you lopped the pipe off at the 'y' and are waqnting made what goes from the 'y' to the new catback ?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Damon
Sep 26, 2015 04:29 PM
