New TPI Cat without tube?
Old Apr 23, 2005 | 05:58 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Hey,
I bought a new seat of Hooker 2055's with AIR tubes, for my 91 Formula TPI... I notice the stock cat has a tube that runs up to the eninge (have not followed it). I'm assuming it connects on on of the set of tubes & the other set connects to something else...
My new cat doesn't have a tube... I read the sticky about TPI & AIR, but didn't get a good explanation of the tubes / system, just whether you should or shouldn't use it...
What is that tube for? Do I need a cat with a tube?? If not, that would be disabling half the system??
Thanks,
Rafael
Old Apr 23, 2005 | 11:18 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
that tube goes up and into the air box on the passenger side(big black box with a buch of hoses going to it) from there they go to the pump and to the manifolds. Its used to blow air into the cats to reduce emissions. Hope that helps.
Justin
Old Apr 24, 2005 | 05:13 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Justin
My tube went directly to the manifolds. Most likely your cat is just a different style, that does not require air injection. Just remove the tube and block the hole.
Old Apr 24, 2005 | 06:55 PM
luvofjah's Avatar
I will check where my tube goes... if it goes to the manifold ( I hope it does) I can just cap it...
My car is not a daily driver, project car... they don't give licenses to legally blind people...
Raf
Old Apr 24, 2005 | 07:48 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Thats cool man! I bet you can sneak her into a parking lot with assistance But yeah mine was easy to take out. Only problem was trying to get the tube from the top, it was kinda tight and got stuck between the firewall and block. Maybe if you can get it high enough you can go through the bottom?
Old Apr 24, 2005 | 10:15 PM
luvofjah's Avatar
There are many things I've done myself, upgraded LCA's & Panard Bar, Bilstein Shocks, Strut Tower Brace & Wonder bar, Pro 5.0 shifter, etc... I'll probably leave the tube to the headers / exhaust / ignition system upgrade to the mechanic I will pay...
I have some vision, just not enough to get a license... My dad taught me to drive stick shift when I was 11... I've always loved cars & it's something I can tinker with...
Thanks to this site & all the helpful people.
Rafael
LT1Formula
20
Nov 14, 2015 12:02 AM
Out-Cast
Aug 22, 2015 07:49 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
