manifold bolt help please
Old May 3, 2005 | 11:31 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Anyone have a trick to get the locking thing from the factory off farthest towards the firewall bolt on the driver's side? I've been struggling with it for at least a hour.
Old May 3, 2005 | 12:44 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
A long screwdriver and a hammer usually takes care of it. I take it you can't get the tab bent back?
Old May 3, 2005 | 01:20 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Problem being i cant get an angle to do that, thats how i got the otherbolts off.
Old May 3, 2005 | 01:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I can't help much because I cheated - took the engine out of the car first.
A small pry bar ( http://www.harborfreight.com/cpi/cta...169&pricetype= ) might get the job done.
Old May 3, 2005 | 01:40 PM
406TPI's Avatar
Car: 1985 IROC-Z
Can you get to it from the bottom? Another thing that I've done in the past...when the tabs are real rusty is to find another socket that will go over the tab and bolt head and give it a turn, it will sometimes break the tab off.
Old May 3, 2005 | 09:05 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I used a really small flat head screw driver. A stubby one.
It was a huge PITA. I don't know why GM decided to do that to them.
Old May 4, 2005 | 12:23 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Yeah, i took a small stubby screwdriver to it and bent it out then pushed it out... 4 hours later the drivers side is out... didnt have to remove anythin, still need to drop the y pipe.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
